Add a reporting node and its HA partner to a LUN map
POST /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}/reporting-nodes
Introduced In: 9.10
Adds a reporting node and its HA partner to a LUN map.
Required properties
uuidorname- A cluster node to add.
Related ONTAP commands
lun mapping add-reporting-nodes
lun.uuid |
string |
path |
True |
The unique identifier of the LUN. |
igroup.uuid |
string |
path |
True |
The unique identifier of the igroup. |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
_links |
igroup |
The initiator group of the LUN map of the reporting node. |
lun |
The LUN of the LUN map of the reporting node. |
name |
string |
The name of the node. Either |
uuid |
string |
The unique identifier of the node. Either |
Example request
"igroup": {
"lun": {
"name": "node1",
"uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[lun_map_reporting_node] |
"num_records": 1,
"records": [
"igroup": {
"lun": {
"name": "node1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374875 |
The specified LUN does not exist or is not accessible to the caller. |
5374878 |
The specified initiator group does not exist, is not accessible to the caller, or is not in the same SVM as the specified LUN. |
5374920 |
The specified cluster node does not exist. |
5374921 |
The specified cluster node name and UUID do not refer to the same cluster node. |
5374922 |
The specified LUN map does not exist. |
5374923 |
A cluster node |
href |
string |
_links
igroup
uuid |
string |
The unique identifier of the initiator group. |
lun
uuid |
string |
A cluster node from which network paths to the LUN are advertised by ONTAP via the SAN protocols.
_links |
igroup |
lun |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
