REST API reference
Re-key SVM KEK for an AWS KMS
Rekeys the SVM KEK with a specific AWS KMS, ensuring that your security management keys are updated according to your requirements.
HTTP method and endpoint
POST /security/aws-kms/{aws_kms.uuid}/rekey-internal
Introduced in
ONTAP 9.12
Usage notes
Rekeys SVM KEK for the given AWS KMS.
  • security key-manager external aws rekey-internal
aws_kms.uuid
string
path
True
UUID of the existing AWS KMS configuration.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
65537547
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation.
65537556
Unable to successfully encrypt or decrypt because the configured external key manager for the given SVM is in a blocked state.
65537559
There are no existing internal keys for the SVM. A rekey operation is allowed for an SVM with one or more encryption keys.
65537566
Internal error. All nodes in the cluster are not currently online.
65537926
AWS KMS is not configured for the given SVM.
Name Type Description
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
