Re-key SVM KEK for an AWS KMS
Rekeys the SVM KEK for the specified AWS KMS, ensuring that the key encryption key remains secure and up-to-date.
HTTP method and endpoint
POST /security/aws-kms/{aws_kms.uuid}/rekey-internal
Introduced in
ONTAP 9.12
Usage notes
Rekeys SVM KEK for the given AWS KMS.
Related ONTAP commands
security key-manager external aws rekey-internal
aws_kms.uuid |
string |
path |
True |
UUID of the existing AWS KMS configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537547 |
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation. |
65537556 |
Unable to successfully encrypt or decrypt because the configured external key manager for the given SVM is in a blocked state. |
65537559 |
There are no existing internal keys for the SVM. A rekey operation is allowed for an SVM with one or more encryption keys. |
65537566 |
Internal error. All nodes in the cluster are not currently online. |
65537926 |
AWS KMS is not configured for the given SVM. |
| Name | Type | Description |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
