Re-key SVM KEK for an AWS KMS
Rekeys the SVM KEK for the specified AWS KMS, updating the encryption key to ensure data security.
HTTP method and endpoint
POST /security/aws-kms/{aws_kms.uuid}/rekey-internal
Introduced in
ONTAP 9.12
Usage notes
Rekeys SVM KEK for the given AWS KMS.
Related ONTAP commands
security key-manager external aws rekey-internal
aws_kms.uuid |
string |
path |
True |
UUID of the existing AWS KMS configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537547 |
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation. |
65537556 |
Unable to successfully encrypt or decrypt because the configured external key manager for the given SVM is in a blocked state. |
65537559 |
There are no existing internal keys for the SVM. A rekey operation is allowed for an SVM with one or more encryption keys. |
65537566 |
Internal error. All nodes in the cluster are not currently online. |
65537610 |
Rekey cannot be performed on the SVM while the enabled keystore configuration is being switched. If a previous attempt to switch the keystore configuration failed, or was interrupted, the system will continue to prevent rekeying for the SVM. Use the REST API PATCH method "/api/security/key-stores/{uuid}" to re-run and complete the operation. |
65537926 |
AWS KMS is not configured for the given SVM. |
65539436 |
Rekey cannot be performed on the SVM while the enabled keystore configuration is being initialized. Wait until the keystore is in the active state, and rerun the rekey operation. |
65539437 |
Rekey cannot be performed on the SVM while the enabled keystore configuration is being disabled. |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
