Create an IPsec policy
Creates an IPsec policy to define the rules and parameters for securing IP traffic between endpoints. This is useful for establishing secure communication channels in your network infrastructure.
HTTP method and endpoint
POST /security/ipsec/policies
Introduced in
ONTAP 9.8
Related ONTAP commands
security ipsec policy create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
action |
string |
Action for the IPsec policy. |
authentication_method |
string |
Authentication method for the IPsec policy. |
certificate |
Certificate for the IPsec policy. |
enabled |
boolean |
Indicates whether or not the policy is enabled. |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input. |
local_endpoint |
Local endpoint for the IPsec policy. |
local_identity |
string |
Local Identity |
name |
string |
IPsec policy name. |
protocol |
string |
Lower layer protocol to be covered by the IPsec policy. |
remote_endpoint |
Remote endpoint for the IPsec policy. |
remote_identity |
string |
Remote Identity |
secret_key |
string |
Pre-shared key for IKE negotiation. |
svm |
uuid |
string |
Unique identifier of the IPsec policy. |
Example request
"action": "string",
"authentication_method": "string",
"certificate": {
"name": "cert1",
"ipspace": {
"name": "exchange",
"local_endpoint": {
"address": "10.10.10.7",
"netmask": "24",
"port": "23"
"local_identity": "string",
"name": "string",
"protocol": "17",
"remote_endpoint": {
"netmask": "24",
"port": "23"
"remote_identity": "string",
"secret_key": "string",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[records] |
"num_records": 1,
"records": [
"action": "string",
"certificate": {
"name": "cert1",
"ipspace": {
"name": "exchange",
"local_endpoint": {
"netmask": "24",
"port": "23"
"name": "string",
"protocol": "17",
"netmask": "24",
"port": "23"
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66257099 |
Only one protocol can be specified. |
66257100 |
Only one local port can be specified. |
66257101 |
Only one remote port can be specified. |
66257104 |
IPsec policy with same name already exists in this SVM. |
66257107 |
The specified pre-shared key is not a valid hexadecimal string. |
66257109 |
The specified pre-shared key is not a valid Base64 encoded binary string. |
66257110 |
Failed to a create policy sequencing value. |
66257111 |
The IPsec policy with action ESP TRANSPORT provides packet protection and requires a secret key or certificate for authentication. |
66257112 |
The IPsec policy with the action specified does not provide packet protection and the authentication method provided for the policy will be ignored. |
66257113 |
Only one local IP subnet can be specified. |
66257114 |
Only one remote IP subnet can be specified. |
66257115 |
Port ranges containing more than one port are not supported. |
66257117 |
IPsec is not supported on the SVM specified in the policy, IPsec is supported on data SVMs only. |
66257120 |
The subnet selector must be a host address (An IPv4 address with a 32-bit netmask or an IPv6 address with a 128-bit netmask). |
66257121 |
The maximum limit of IPsec Policies has reached for the specified SVM. |
66257125 |
The local_endpoint.address must be specified with local_endpoint.netmask. |
66257126 |
The remote_endpoint.address must be specified with remote_endpoint.netmask. |
66257132 |
Invalid value for port field. Value should be in range <1-65535>. |
66257133 |
A pre-shared key is needed for the PSK authentication method. Use the secret_key option to specify a key. |
66257134 |
An end-entity certificate is needed for the PKI authentication method. Use the certificate.uuid option to specify an end-entity certificate. |
66257137 |
A pre-shared key is not needed for the PKI authentication method. |
66257139 |
Certificate with the specified UUID was not found. |
66257140 |
Only certificates with a client or server type are supported. |
66257396 |
IPsec is not supported for the admin SVM in a MetroCluster configuration. |
href |
string |
_links
certificate
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
local_endpoint
address |
string |
IPv4 or IPv6 address |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
port |
string |
Application port to be covered by the IPsec policy |
remote_endpoint
address |
string |
netmask |
string |
port |
string |
svm
name |
string |
The name of the SVM. |
uuid |
string |
ipsec_policy
IPsec policy object.
action |
string |
string |
certificate |
enabled |
boolean |
ipspace |
local_endpoint |
local_identity |
string |
Local Identity |
name |
string |
protocol |
string |
remote_endpoint |
remote_identity |
string |
Remote Identity |
secret_key |
string |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
records
action |
string |
string |
certificate |
enabled |
boolean |
ipspace |
local_endpoint |
local_identity |
string |
Local Identity |
name |
string |
protocol |
string |
remote_endpoint |
remote_identity |
string |
Remote Identity |
secret_key |
string |
svm |
uuid |
string |
