REST API reference
Create an IPsec policy
POST /security/ipsec/policies
Introduced In: 9.8
Creates an IPsec policy.
  • security ipsec policy create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
action
string
Action for the IPsec policy.
authentication_method
string
Authentication method for the IPsec policy.
certificate
certificate
Certificate for the IPsec policy.
certificate_modify_keepsa
boolean
Indicates whether old security associations are kept upon certificate modification.
enabled
boolean
Indicates whether or not the policy is enabled.
ipspace
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
local_endpoint
local_endpoint
Local endpoint for the IPsec policy.
local_identity
string
Local Identity
name
string
IPsec policy name.
ppk
ppk
Post-quantum pre-shared key information.
protocol
string
Lower layer protocol to be covered by the IPsec policy.
remote_endpoint
remote_endpoint
Remote endpoint for the IPsec policy.
remote_identity
string
Remote Identity
secret_key
string
Pre-shared key for IKE negotiation.
svm
svm
uuid
string
Unique identifier of the IPsec policy.
Example request
  "action": "string",
  "authentication_method": "string",
  "certificate": {
    "name": "string",
  "ipspace": {
    "name": "Default",
  "local_endpoint": {
    "address": "10.10.10.7",
    "netmask": "24",
    "port": "23"
  "local_identity": "string",
  "name": "string",
  "ppk": {
    "identity": "string",
    "shared_key": "string"
  "protocol": "17",
  "remote_endpoint": {
    "netmask": "24",
    "port": "23"
  "remote_identity": "string",
  "secret_key": "string",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[records]
  "num_records": 1,
  "records": [
      "action": "string",
      "certificate": {
        "name": "string",
      "ipspace": {
        "name": "Default",
      "local_endpoint": {
        "netmask": "24",
        "port": "23"
      "name": "string",
      "ppk": {
      "protocol": "17",
        "netmask": "24",
        "port": "23"
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
66257099
Only one protocol can be specified.
66257100
Only one local port can be specified.
66257101
Only one remote port can be specified.
66257102
Internet Key Exchange version 1 (IKEv1) is not supported.
66257104
IPsec policy with same name already exists in this SVM.
66257107
The specified pre-shared key is not a valid hexadecimal string.
66257109
The specified pre-shared key is not a valid Base64 encoded binary string.
66257110
Failed to a create policy sequencing value.
66257112
The IPsec policy with the action specified does not provide packet protection and the authentication method provided for the policy will be ignored.
66257113
Only one local IP subnet can be specified.
66257114
Only one remote IP subnet can be specified.
66257115
Port ranges containing more than one port are not supported.
66257117
IPsec is not supported on the SVM specified in the policy, IPsec is supported on data SVMs only.
66257120
The subnet selector must be a host address (An IPv4 address with a 32-bit netmask or an IPv6 address with a 128-bit netmask).
66257121
The maximum limit of IPsec policies has been reached for the specified SVM.
66257125
The local_endpoint.address must be specified with local_endpoint.netmask.
66257126
The remote_endpoint.address must be specified with remote_endpoint.netmask.
66257127
The local subnet must be configured as a non-zero subnet.
66257128
Invalid ANY wildcard subnet.
66257129
A specific local or remote port number is required when the remote subnet is configured as an ANY wildcard subnet.
66257130
The maximum limit of IPsec policies has been reached for the cluster.
66257131
ESP in UDPv6 Encapsulation is not supported.
66257132
Invalid value for port field. Value should be in range <0-65535>.
66257133
A pre-shared key is needed for the PSK authentication method. Use the secret_key option to specify a key.
66257134
An end-entity certificate is needed for the PKI authentication method. Use the certificate.uuid option to specify an end-entity certificate.
66257135
The specified certificate is not found on the SVM.
66257136
A certificate is not needed for the PSK authentication method.
66257137
A pre-shared key is not needed for the PKI authentication method.
66257138
Remote identity is required when using certificate verification.
66257139
Certificate with the specified UUID was not found.
66257140
Only certificates with a client or server type are supported.
66257142
Failed to create IPsec policy because the specified SVM is being migrated.
66257143
Invalid IPsec policy provided. The subnet must be non-empty.
66257144
The IPsec policy actions ESP TRANSPORT and ESP UDP each provide packet protection and requires a secret key or certificate for authentication.
66257148
The policy name does not meet required ASCII-range characters length.
66257153
The policy requires a post-quantum pre-shared key because ppk-identity is specified for this policy.
66257154
The policy requires a post-quantum pre-shared identity because ppk-shared-key is specified for this policy.
66257199
Not all of the nodes in the cluster are running a version that supports the IPsec feature.
66257200
The shared key does not meet required ASCII-range characters length.
66257201
Support for the feature available with effective cluster version or later.
66257202
The specified SVM name is invalid.
66257203
The specified SVM UUID is invalid.
66257204
The specified IPspace UUID and IPspace name refer to different IPspaces.
66257205
The specified SVM must exist in the specified IPspace.
66257305
The certificate UUID does not match the provided certificate name.
66257396
IPsec is not supported for the admin SVM in a MetroCluster configuration.
string
certificate
name
string
Certificate name
uuid
string
Certificate UUID
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
local_endpoint
address
string
IPv4 or IPv6 address
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
port
string
Application port to be covered by the IPsec policy
ppk
identity
string
Post-quantum pre-shared key identity.
shared_key
string
Post-quantum pre-shared key.
remote_endpoint
address
string
netmask
string
port
string
svm
name
string
uuid
string
ipsec_policy
IPsec policy object.
action
string
string
certificate
certificate
boolean
enabled
boolean
ipspace
ipspace
local_endpoint
local_endpoint
local_identity
string
Local Identity
name
string
IPsec policy name.
ppk
ppk
protocol
string
remote_endpoint
remote_endpoint
remote_identity
string
Remote Identity
secret_key
string
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
records
action
string
string
certificate
certificate
boolean
enabled
boolean
ipspace
ipspace
local_endpoint
local_endpoint
local_identity
string
Local Identity
name
string
IPsec policy name.
ppk
ppk
protocol
string
remote_endpoint
remote_endpoint
remote_identity
string
Remote Identity
secret_key
string
svm
svm
uuid
string
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
