Create an IPsec policy
Creates an IPsec policy to define the security parameters for encrypting and authenticating IP traffic between network devices. This is typically used to enhance the security of data transmitted over your network.
HTTP method and endpoint
POST /security/ipsec/policies
Introduced in
ONTAP 9.8
Related ONTAP commands
security ipsec policy create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
action |
string |
Action for the IPsec policy. |
authentication_method |
string |
Authentication method for the IPsec policy. |
certificate |
Certificate for the IPsec policy. |
enabled |
boolean |
Indicates whether or not the policy is enabled. |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input. |
local_endpoint |
Local endpoint for the IPsec policy. |
local_identity |
string |
Local Identity |
name |
string |
IPsec policy name. |
ppk |
Post-quantum pre-shared key information. |
protocol |
string |
Lower layer protocol to be covered by the IPsec policy. |
remote_endpoint |
Remote endpoint for the IPsec policy. |
remote_identity |
string |
Remote Identity |
secret_key |
string |
Pre-shared key for IKE negotiation. |
svm |
uuid |
string |
Unique identifier of the IPsec policy. |
Example request
"action": "string",
"authentication_method": "string",
"certificate": {
"name": "string",
"ipspace": {
"name": "Default",
"local_endpoint": {
"address": "10.10.10.7",
"netmask": "24",
"port": "23"
"local_identity": "string",
"name": "string",
"ppk": {
"identity": "string",
"shared_key": "string"
"protocol": "17",
"remote_endpoint": {
"netmask": "24",
"port": "23"
"remote_identity": "string",
"secret_key": "string",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[records] |
"num_records": 1,
"records": [
"action": "string",
"certificate": {
"name": "string",
"ipspace": {
"name": "Default",
"local_endpoint": {
"netmask": "24",
"port": "23"
"name": "string",
"ppk": {
"protocol": "17",
"netmask": "24",
"port": "23"
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66257099 |
Only one protocol can be specified. |
66257100 |
Only one local port can be specified. |
66257101 |
Only one remote port can be specified. |
66257102 |
Internet Key Exchange version 1 (IKEv1) is not supported. |
66257104 |
IPsec policy with same name already exists in this SVM. |
66257107 |
The specified pre-shared key is not a valid hexadecimal string. |
66257109 |
The specified pre-shared key is not a valid Base64 encoded binary string. |
66257110 |
Failed to a create policy sequencing value. |
66257112 |
The IPsec policy with the action specified does not provide packet protection and the authentication method provided for the policy will be ignored. |
66257113 |
Only one local IP subnet can be specified. |
66257114 |
Only one remote IP subnet can be specified. |
66257115 |
Port ranges containing more than one port are not supported. |
66257117 |
IPsec is not supported on the SVM specified in the policy, IPsec is supported on data SVMs only. |
66257120 |
The subnet selector must be a host address (An IPv4 address with a 32-bit netmask or an IPv6 address with a 128-bit netmask). |
66257121 |
The maximum limit of IPsec policies has been reached for the specified SVM. |
66257125 |
The local_endpoint.address must be specified with local_endpoint.netmask. |
66257126 |
The remote_endpoint.address must be specified with remote_endpoint.netmask. |
66257127 |
The local subnet must be configured as a non-zero subnet. |
66257128 |
Invalid ANY wildcard subnet. |
66257129 |
A specific local or remote port number is required when the remote subnet is configured as an ANY wildcard subnet. |
66257130 |
The maximum limit of IPsec policies has been reached for the cluster. |
66257131 |
ESP in UDPv6 Encapsulation is not supported. |
66257132 |
Invalid value for port field. Value should be in range <0-65535>. |
66257133 |
A pre-shared key is needed for the PSK authentication method. Use the secret_key option to specify a key. |
66257134 |
An end-entity certificate is needed for the PKI authentication method. Use the certificate.uuid option to specify an end-entity certificate. |
66257135 |
The specified certificate is not found on the SVM. |
66257136 |
A certificate is not needed for the PSK authentication method. |
66257137 |
A pre-shared key is not needed for the PKI authentication method. |
66257138 |
Remote identity is required when using certificate verification. |
66257139 |
Certificate with the specified UUID was not found. |
66257140 |
Only certificates with a client or server type are supported. |
66257142 |
Failed to create IPsec policy because the specified SVM is being migrated. |
66257143 |
Invalid IPsec policy provided. The subnet must be non-empty. |
66257144 |
The IPsec policy actions ESP TRANSPORT and ESP UDP each provide packet protection and requires a secret key or certificate for authentication. |
66257148 |
The policy name does not meet required ASCII-range characters length. |
66257153 |
The policy requires a post-quantum pre-shared key because ppk-identity is specified for this policy. |
66257154 |
The policy requires a post-quantum pre-shared identity because ppk-shared-key is specified for this policy. |
66257199 |
Not all of the nodes in the cluster are running a version that supports the IPsec feature. |
66257200 |
The shared key does not meet required ASCII-range characters length. |
66257201 |
Support for the feature available with effective cluster version or later. |
66257202 |
The specified SVM name is invalid. |
66257203 |
The specified SVM UUID is invalid. |
66257204 |
The specified IPspace UUID and IPspace name refer to different IPspaces. |
66257205 |
The specified SVM must exist in the specified IPspace. |
66257305 |
The certificate UUID does not match the provided certificate name. |
66257396 |
IPsec is not supported for the admin SVM in a MetroCluster configuration. |
href |
string |
_links
certificate
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
local_endpoint
address |
string |
IPv4 or IPv6 address |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
port |
string |
Application port to be covered by the IPsec policy |
ppk
identity |
string |
Post-quantum pre-shared key identity. |
shared_key |
string |
Post-quantum pre-shared key. |
remote_endpoint
address |
string |
netmask |
string |
port |
string |
svm
name |
string |
uuid |
string |
ipsec_policy
IPsec policy object.
action |
string |
string |
certificate |
enabled |
boolean |
ipspace |
local_endpoint |
local_identity |
string |
Local Identity |
name |
string |
ppk |
protocol |
string |
remote_endpoint |
remote_identity |
string |
Remote Identity |
secret_key |
string |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
records
action |
string |
string |
certificate |
enabled |
boolean |
ipspace |
local_endpoint |
local_identity |
string |
Local Identity |
name |
string |
ppk |
protocol |
string |
remote_endpoint |
remote_identity |
string |
Remote Identity |
secret_key |
string |
svm |
uuid |
string |
returned_error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
