Migrate SVM keys between security key managers
Migrates keys between an SVM's security key managers, facilitating the transition of key management responsibilities between different key manager configurations.
HTTP method and endpoint
POST /security/key-managers/{source.uuid}/migrate
Introduced in
ONTAP 9.7
Usage notes
Migrates the keys belonging to an SVM between the cluster's key manager and the SVM's key manager. This operation can run for several minutes.
Required properties
source.uuid- UUID of the source key manager. -
uuid- UUID of the destination key manager. The UUID of onboard and external KMIP key manager can be fetched using [GET /api/security/key-managers]. The UUID of Azure Key Vault key manager can be fetched using [GET /api/security/azure-key-vaults]. The UUID of Google Cloud key manager can be fetched using [GET /api/security/gcp-kms].
Related ONTAP commands
security key-manager migrate
source.uuid |
string |
path |
True |
Migration source key manager UUID |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
uuid |
string |
Key manager UUID |
Example request
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536886 |
The specified migration option is not supported in this release. |
65536959 |
The source-uuid and UUID must be different values. |
65536968 |
Check that all nodes of the cluster are healthy and retry the operation. |
65537117 |
The migrate operation cannot be started because a UUID cannot be converted to an SVM name. |
65537117 |
Cannot start migration because a key manager referenced by a provided UUID does not exist. |
65537551 |
Top-level internal key protection key (KEK) is unavailable on one or more nodes. |
65537552 |
Embedded KMIP server status is not available. |
65537564 |
Check that the Azure Key Vault Service is healthy and retry the operation. |
65537720 |
Failed to configure the Google Cloud Key Management Service for an SVM because a key manager is already configured. |
65537736 |
Check that the Google Cloud Key Management Service is healthy and retry the operation. |
65538107 |
Key migration to an IBM Key Lore key manager is not supported. |
href |
string |
_links
info
Migration destination key manager UUID
uuid |
string |
Key manager UUID |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
