REST API reference
Migrate SVM keys between security key managers
Migrates the keys of an SVM between the cluster's key manager and the SVM's key manager. This operation is useful when transitioning keys to a different key management system within your storage environment.
HTTP method and endpoint
POST /security/key-managers/{source.uuid}/migrate
Introduced in
ONTAP 9.7
Usage notes
Migrates the keys belonging to an SVM between the cluster's key manager and the SVM's key manager. This operation can run for several minutes.
Required properties
  • source.uuid - UUID of the source key manager.
  • uuid - UUID of the destination key manager. The UUID of onboard and external KMIP key manager can be fetched using [GET /api/security/key-managers]. The UUID of Azure Key Vault key manager can be fetched using [GET /api/security/azure-key-vaults]. The UUID of Google Cloud key manager can be fetched using [GET /api/security/gcp-kms].
  • security key-manager migrate
source.uuid
string
path
True
Migration source key manager UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
uuid
string
Key manager UUID
Example request
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
65536886
The specified migration option is not supported in this release.
65536959
The source-uuid and UUID must be different values.
65536968
Check that all nodes of the cluster are healthy and retry the operation.
65537117
The migrate operation cannot be started because a UUID cannot be converted to an SVM name.
65537117
Cannot start migration because a key manager referenced by a provided UUID does not exist.
65537551
Top-level internal key protection key (KEK) is unavailable on one or more nodes.
65537552
Embedded KMIP server status is not available.
65537564
Check that the Azure Key Vault Service is healthy and retry the operation.
65537720
Failed to configure the Google Cloud Key Management Service for an SVM because a key manager is already configured.
65537736
Check that the Google Cloud Key Management Service is healthy and retry the operation.
65538107
Key migration to an IBM Key Lore key manager is not supported.
string
info
Migration destination key manager UUID
uuid
string
Key manager UUID
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
