Migrate SVM keys between security key managers
POST /security/key-managers/{source.uuid}/migrate
Introduced In: 9.7
Migrates the keys belonging to an SVM between the cluster's key manager and the SVM's key manager. This operation can run for several minutes.
Required properties
source.uuid- UUID of the source key manager. -
uuid- UUID of the destination key manager. The UUID of onboard and external KMIP key manager can be fetched using [GET /api/security/key-managers]. The UUID of Azure Key Vault key manager can be fetched using [GET /api/security/azure-key-vaults]. The UUID of Google Cloud key manager can be fetched using [GET /api/security/gcp-kms]. The UUID of Amazon Web Services key manager can be fetched using [GET /api/security/aws-kms].
Related ONTAP commands
security key-manager key migrate
source.uuid |
string |
path |
True |
Migration source key manager UUID |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
uuid |
string |
Key manager UUID |
Example request
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536886 |
The specified migration option is not supported in this release. |
65536959 |
The source-uuid and UUID must be different values. |
65536968 |
Check that all nodes of the cluster are healthy and retry the operation. |
65537117 |
The migrate operation cannot be started because a UUID cannot be converted to an SVM name. |
65537117 |
Cannot start migration because a key manager referenced by a provided UUID does not exist. |
65537551 |
Top-level internal key protection key (KEK) is unavailable on one or more nodes. |
65537552 |
Embedded KMIP server status is not available. |
65537564 |
Check that the Azure Key Vault Service is healthy and retry the operation. |
65537611 |
Key migration cannot be performed on the SVM while the enabled keystore configuration is being switched. If a previous attempt to switch the keystore configuration failed, or was interrupted, the system will continue to prevent key migration for the SVM. Use the REST API PATCH method "/api/security/key-stores/{uuid}" to re-run and complete the operation. |
65537720 |
Failed to configure the Google Cloud Key Management Service for an SVM because a key manager is already configured. |
65537736 |
Check that the Google Cloud Key Management Service is healthy and retry the operation. |
65538107 |
Key migration to an IBM Key Lore key manager is not supported. |
65539434 |
Cannot perform key migration on the SVM while the keystore is being initialized. Wait until the keystore is in the active state, and rerun the key migration operation. |
65539435 |
Cannot perform key migration on the SVM while the keystore is being disabled. |
href |
string |
_links
info
Migration destination key manager UUID
uuid |
string |
Key manager UUID |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
