Add an attribute to a LUN
Adds an attribute to a LUN to customize its properties and manage storage configurations effectively.
HTTP method and endpoint
POST /storage/luns/{lun.uuid}/attributes
Introduced in
ONTAP 9.10
Required properties
name- The name of the attribute to add. -
value- The value of the attribute to add.
Learn more
lun.uuid |
string |
path |
True |
The unique identifier of the LUN. |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
lun |
The LUN for which the attribute is set. |
name |
string |
The attribute name. Required in POST. |
value |
string |
The attribute value. Required in POST; valid in PATCH. |
Example request
"lun": {
"name": "name1",
"value": "value1"
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[lun_attribute] |
"num_records": 1,
"records": [
"lun": {
"name": "name1",
"value": "value1"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374875 |
The specified LUN was not found. |
5374928 |
An incomplete attribute name/value pair was supplied. |
5374929 |
The combined sizes of an attribute name and value are too large. |
5374930 |
The attribute already exists for the LUN. |
href |
string |
_links
lun
uuid |
string |
lun_attribute
A name/value pair optionally stored with the LUN. Attributes are available to callers to persist small amounts of application-specific metadata. They are in no way interpreted by ONTAP.
Attribute names and values must be at least one byte and no more than 4091 bytes in length. The sum of the name and value lengths must be no more than 4092 bytes.
lun |
name |
string |
value |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
