REST API reference
Add an attribute to a LUN
Adds an attribute to a LUN by specifying its name and value, enhancing the LUN's metadata configuration.
HTTP method and endpoint
POST /storage/luns/{lun.uuid}/attributes
Introduced in
ONTAP 9.10
Required properties
  • name - The name of the attribute to add.
  • value - The value of the attribute to add.
lun.uuid
string
path
True
The unique identifier of the LUN.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
lun
lun
The LUN for which the attribute is set.
name
string
The attribute name. Required in POST.
value
string
The attribute value. Required in POST; valid in PATCH.
Example request
  "lun": {
  "name": "name1",
  "value": "value1"
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[lun_attribute]
  "num_records": 1,
  "records": [
      "lun": {
      "name": "name1",
      "value": "value1"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
5374875
The specified LUN was not found.
5374928
An incomplete attribute name/value pair was supplied.
5374929
The combined sizes of an attribute name and value are too large.
5374930
The attribute already exists for the LUN.
string
lun
uuid
string
lun_attribute
A name/value pair optionally stored with the LUN. Attributes are available to callers to persist small amounts of application-specific metadata. They are in no way interpreted by ONTAP.
Attribute names and values must be at least one byte and no more than 4091 bytes in length. The sum of the name and value lengths must be no more than 4092 bytes.
lun
lun
name
string
value
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
