REST API reference
Add an attribute to a LUN
Adds an attribute to a LUN to extend its configuration with additional metadata.
HTTP method and endpoint
POST /storage/luns/{lun.uuid}/attributes
Introduced in
ONTAP 9.10
Required properties
  • name - The name of the attribute to add.
  • value - The value of the attribute to add.
lun.uuid
string
path
True
The unique identifier of the LUN.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
lun
lun
The LUN for which the attribute is set.
name
string
The attribute name. Required in POST.
value
string
The attribute value. Required in POST; valid in PATCH.
Example request
  "lun": {
  "name": "name1",
  "value": "value1"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
5374875
The specified LUN was not found.
5374928
An incomplete attribute name/value pair was supplied.
5374929
The combined sizes of an attribute name and value are too large.
5374930
The attribute already exists for the LUN.
5375060
The copy start operation failed.
string
lun
uuid
string
lun_attribute
A name/value pair optionally stored with the LUN. Attributes are available to callers to persist small amounts of application-specific metadata. They are in no way interpreted by ONTAP.
Attribute names and values must be at least one byte and no more than 4091 bytes in length. The sum of the name and value lengths must be no more than 4092 bytes.
lun
lun
name
string
value
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
