Create a QoS policy
Creates a QoS policy to define performance service levels for your storage resources. Use this endpoint to establish specific parameters for managing workload performance within your ONTAP environment.
HTTP method and endpoint
POST /storage/qos/policies
Introduced in
ONTAP 9.6
Required properties
svm.uuidorsvm.name- The existing SVM owning the QoS policy. -
name- The name of the QoS policy. -
fixed.*oradaptive.*- Either of the fixed or adaptive parameters.
Default property values
If
fixed.*parameters are specified, then capacity.shared is set to false by default.
Related ONTAP commands
qos policy-group create -
qos adaptive-policy-group create
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
adaptive |
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space. |
fixed |
QoS policy-groups define a fixed service level objective (SLO) for a storage object. |
name |
string |
Name of the QoS policy. |
object_count |
integer |
Number of objects attached to this policy. |
pgid |
integer |
Policy group ID of the QoS policy. |
policy_class |
string |
Class of the QoS policy. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
svm |
uuid |
string |
Example request
"adaptive": {
"block_size": "string",
"expected_iops_allocation": "string",
"peak_iops_allocation": "string"
"name": "extreme",
"object_count": 0,
"pgid": 0,
"policy_class": "string",
"scope": "string",
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
8454147 |
The maximum limit for QoS policies has been reached. |
8454154 |
The name specified for creating conflicts with an existing QoS policy name. |
8454260 |
Invalid value for maximum and minimum fields. Valid values for max_throughput_iops and max_throughput_mbps combination is for the ratio of max_throughput_mbps and max_throughput_iops to be within 1 to 4096. |
8454273 |
Invalid value for an adaptive field. Value should be non-zero. |
8454277 |
The name specified for creating an adaptive QoS policy conflicts with an existing fixed QoS policy name. |
8454278 |
The name specified for creating a fixed QoS policy conflicts with an existing adaptive QoS policy name. |
href |
string |
_links
adaptive
absolute_min_iops |
integer |
Specifies the absolute minimum IOPS that is used as an override when the expected_iops is less than this value. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
block_size |
string |
Specifies the block size |
expected_iops |
integer |
Expected IOPS. Specifies the minimum expected IOPS per TB allocated based on the storage object allocated size. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
expected_iops_allocation |
string |
Specifies the size to be used to calculate expected IOPS per TB. The size options are either the storage object allocated space or the storage object used space. |
peak_iops |
integer |
Peak IOPS. Specifies the maximum possible IOPS per TB allocated based on the storage object allocated size or the storage object used size. |
peak_iops_allocation |
string |
Specifies the size to be used to calculate peak IOPS per TB. The size options are either the storage object allocated space or the storage object used space. |
fixed
capacity_shared |
boolean |
Specifies whether the capacities are shared across all objects that use this QoS policy-group. Default is false. |
max_throughput_iops |
integer |
Maximum throughput defined by this policy. It is specified in terms of IOPS. 0 means no maximum throughput is enforced. |
max_throughput_mbps |
integer |
Maximum throughput defined by this policy. It is specified in terms of Mbps. 0 means no maximum throughput is enforced. |
min_throughput_iops |
integer |
Minimum throughput defined by this policy. It is specified in terms of IOPS. 0 means no minimum throughput is enforced. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
min_throughput_mbps |
integer |
Minimum throughput defined by this policy. It is specified in terms of Mbps. 0 means no minimum throughput is enforced. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
qos_policy
adaptive |
fixed |
name |
string |
object_count |
integer |
pgid |
integer |
policy_class |
string |
scope |
string |
svm |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
