Create a QoS policy
Creates a QoS policy to manage and control the performance of workloads on your storage system. Use this endpoint to define the parameters and settings that determine how resources are allocated to different workloads, ensuring effective performance management.
HTTP method and endpoint
POST /storage/qos/policies
Introduced in
ONTAP 9.6
Required properties
svm.uuidorsvm.name- The existing SVM owning the QoS policy. -
name- The name of the QoS policy. -
fixed.*oradaptive.*- Either of the fixed or adaptive parameters.
Default property values
If
fixed.*parameters are specified, then capacity.shared is set to false by default.
Related ONTAP commands
qos policy-group create -
qos adaptive-policy-group create
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
adaptive |
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space. |
burst |
Burst settings for the QoS policy. |
fixed |
QoS policy-groups define a fixed service level objective (SLO) for a storage object. |
name |
string |
Name of the QoS policy. |
object_count |
integer |
Number of objects attached to this policy. |
pgid |
integer |
Policy group ID of the QoS policy. |
policy_class |
string |
Class of the QoS policy. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
svm |
uuid |
string |
Example request
"adaptive": {
"block_size": "string",
"expected_iops_allocation": "string",
"peak_iops_allocation": "string"
"fixed": {
"max_throughput": [
"900KB/s",
"500MB/s",
"120GB/s",
"5000IOPS",
"5000IOPS,500KB/s",
"2500IOPS,100MB/s",
"1000IOPS,25MB/s"
"min_throughput": [
"900KB/s",
"500MB/s",
"120GB/s",
"5000IOPS",
"5000IOPS,500KB/s",
"2500IOPS,100MB/s",
"1000IOPS,25MB/s"
"name": "extreme",
"object_count": 0,
"pgid": 0,
"policy_class": "string",
"scope": "string",
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
8454147 |
The maximum limit for QoS policies has been reached. |
8454154 |
The name specified for creating conflicts with an existing QoS policy name. |
8454194 |
The minimum throughput value for the policy group must be less than or equal to the maximum throughput value. |
8454260 |
Invalid value for maximum and minimum fields. Valid values for max_throughput_iops and max_throughput_mbps combination is for the ratio of max_throughput_mbps and max_throughput_iops to be within 1 to 4096. |
8454273 |
Invalid value for an adaptive field. Value should be non-zero. |
8454274 |
Invalid value for an adaptive field. Value for expected_iops must be less than or equal to the value for peak_iops. |
8454277 |
The name specified for creating an adaptive QoS policy conflicts with an existing fixed QoS policy name. |
8454278 |
The name specified for creating a fixed QoS policy conflicts with an existing adaptive QoS policy name. |
8454379 |
The name specified for creating a fixed QoS policy already exists. |
8454380 |
The name specified for creating an adaptive QoS policy already exists. |
8454389 |
One specified field cannot be used in combination with at least one other specified field. |
href |
string |
_links
adaptive
absolute_min_iops |
integer |
Specifies the absolute minimum IOPS that is used as an override when the expected_iops is less than this value. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
block_size |
string |
Specifies the block size |
expected_iops |
integer |
Expected IOPS. Specifies the minimum expected IOPS per TB allocated based on the storage object allocated size. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
expected_iops_allocation |
string |
Specifies the size to be used to calculate expected IOPS per TB. The size options are either the storage object allocated space or the storage object used space. |
peak_iops |
integer |
Peak IOPS. Specifies the maximum possible IOPS per TB allocated based on the storage object allocated size or the storage object used size. |
peak_iops_allocation |
string |
Specifies the size to be used to calculate peak IOPS per TB. The size options are either the storage object allocated space or the storage object used space. |
burst
duration |
integer |
Amount of time in seconds a policy can burst at either the maximum percentage or maximum IOPS above the set limit. |
iops |
integer |
Burst maximum IOPS for a policy max_throughput or peak_iops. Policy max_throughput must have an IOPS component. If burst_iops is less than max_throughput or peak_iops, then max_throughput or peak_iops is used. This is mutually exclusive with burst_percent. |
percent |
integer |
Percentage of IOPS or throughput above policy max_throughput or peak_iops. This is mutually exclusive with burst_iops. |
fixed
capacity_shared |
boolean |
Specifies whether the capacities are shared across all objects that use this QoS policy-group. Default is false. |
max_throughput |
string |
Maximum throughput defined by this policy. It is specified in terms of Kbps, Mbps or Gbps along with or without IOPS. 0 means no maximum throughput is enforced. |
max_throughput_iops |
integer |
Maximum throughput defined by this policy. It is specified in terms of IOPS. 0 means no maximum throughput is enforced. |
max_throughput_mbps |
integer |
Maximum throughput defined by this policy. It is specified in terms of Mbps. 0 means no maximum throughput is enforced. |
min_throughput |
string |
Minimum throughput defined by this policy. It is specified in terms of Kbps, Mbps or Gbps along with or without IOPS. 0 means no minimum throughput is enforced. |
min_throughput_iops |
integer |
Minimum throughput defined by this policy. It is specified in terms of IOPS. 0 means no minimum throughput is enforced. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
min_throughput_mbps |
integer |
Minimum throughput defined by this policy. It is specified in terms of Mbps. 0 means no minimum throughput is enforced. |
svm
name |
string |
uuid |
string |
qos_policy
adaptive |
burst |
fixed |
name |
string |
object_count |
integer |
pgid |
integer |
policy_class |
string |
scope |
string |
svm |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
