REST API reference
Create a QoS policy
Creates a QoS policy to manage and control the performance of storage resources within an existing SVM. This enables you to define specific parameters that dictate how storage performance is allocated and adjusted across workloads.
HTTP method and endpoint
POST /storage/qos/policies
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - The existing SVM owning the QoS policy.
  • name - The name of the QoS policy.
  • fixed.* or adaptive.* - Either of the fixed or adaptive parameters.
Default property values
  • If fixed.* parameters are specified, then capacity.shared is set to false by default.
  • qos policy-group create
  • qos adaptive-policy-group create
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
adaptive
adaptive
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space.
fixed
fixed
QoS policy-groups define a fixed service level objective (SLO) for a storage object.
name
string
Name of the QoS policy.
object_count
integer
Number of objects attached to this policy.
pgid
integer
Policy group ID of the QoS policy.
policy_class
string
Class of the QoS policy.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
svm
svm
uuid
string
Example request
  "adaptive": {
    "block_size": "string",
    "expected_iops_allocation": "string",
    "peak_iops_allocation": "string"
  "name": "extreme",
  "object_count": 0,
  "pgid": 0,
  "policy_class": "string",
  "scope": "string",
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
8454147
The maximum limit for QoS policies has been reached.
8454154
The name specified for creating conflicts with an existing QoS policy name.
8454194
The minimum throughput value for the policy group must be less than or equal to the maximum throughput value.
8454260
Invalid value for maximum and minimum fields. Valid values for max_throughput_iops and max_throughput_mbps combination is for the ratio of max_throughput_mbps and max_throughput_iops to be within 1 to 4096.
8454273
Invalid value for an adaptive field. Value should be non-zero.
8454274
Invalid value for an adaptive field. Value for expected_iops must be less than or equal to the value for peak_iops.
8454277
The name specified for creating an adaptive QoS policy conflicts with an existing fixed QoS policy name.
8454278
The name specified for creating a fixed QoS policy conflicts with an existing adaptive QoS policy name.
8454379
The name specified for creating a fixed QoS policy already exists.
8454380
The name specified for creating an adaptive QoS policy already exists.
string
adaptive
absolute_min_iops
integer
Specifies the absolute minimum IOPS that is used as an override when the expected_iops is less than this value. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
block_size
string
Specifies the block size
expected_iops
integer
Expected IOPS. Specifies the minimum expected IOPS per TB allocated based on the storage object allocated size. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
string
Specifies the size to be used to calculate expected IOPS per TB. The size options are either the storage object allocated space or the storage object used space.
peak_iops
integer
Peak IOPS. Specifies the maximum possible IOPS per TB allocated based on the storage object allocated size or the storage object used size.
string
Specifies the size to be used to calculate peak IOPS per TB. The size options are either the storage object allocated space or the storage object used space.
fixed
capacity_shared
boolean
Specifies whether the capacities are shared across all objects that use this QoS policy-group. Default is false.
max_throughput_iops
integer
Maximum throughput defined by this policy. It is specified in terms of IOPS. 0 means no maximum throughput is enforced.
max_throughput_mbps
integer
Maximum throughput defined by this policy. It is specified in terms of Mbps. 0 means no maximum throughput is enforced.
min_throughput_iops
integer
Minimum throughput defined by this policy. It is specified in terms of IOPS. 0 means no minimum throughput is enforced. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
min_throughput_mbps
integer
Minimum throughput defined by this policy. It is specified in terms of Mbps. 0 means no minimum throughput is enforced.
svm
name
string
uuid
string
qos_policy
adaptive
adaptive
fixed
fixed
name
string
object_count
integer
pgid
integer
policy_class
string
scope
string
svm
svm
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
