REST API reference
Create an EBR policy for an SVM
Creates an Event Based Retention (EBR) policy for a Storage Virtual Machine (SVM) to manage data retention based on specific events. Use this endpoint when you need to define retention policies for compliance or regulatory requirements.
HTTP method and endpoint
POST /storage/snaplock/event-retention/policies
Introduced in
ONTAP 9.7
Usage notes
Creates an Event Based Retention (EBR) policy for an SVM. The input parameter retention_period expects the duration in ISO 8601 format or infinite.
Required properties
  • name - Event retention policy name.
  • retention_period - Retention period of the EBR policy.
  • snaplock event-retention policy create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
name
string
Specifies the EBR policy name
retention_period
string
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively. For example "P10Y" represents a duration of 10 years. Similarly, a duration in hours, minutes is represented by "PTH", "PTM" respectively. The period string must contain only a single time element i.e. either years, months, days, hours or minutes. A duration which combines different periods is not supported, example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the retention period field also accepts the strings "infinite" and "unspecified".
svm
svm
Example request
  "name": "string",
  "retention_period": "P30M",
  "svm": {
    "name": "svm1",
Status: 201, Created
name
string
retention_period
string
svm
svm
  "name": "string",
  "svm": {
    "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default, Error
string
svm
name
string
The name of the SVM.
uuid
string
snaplock_retention_policy
name
string
retention_period
string
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
