Create an EBR policy for an SVM
POST /storage/snaplock/event-retention/policies
Introduced In: 9.7
Creates an Event Based Retention (EBR) policy for an SVM. The input parameter retention_period expects the duration in ISO 8601 format or infinite.
Required properties
name
- Event retention policy name. -
retention_period
- Retention period of the EBR policy.
Related ONTAP commands
snaplock event-retention policy create
Name | Type | In | Required | Description |
return_records |
boolean |
query |
False |
Request Body
Name | Type | Description |
name |
string |
Specifies the EBR policy name |
retention_period |
string |
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "P |
svm |
Example request
"name": "string",
"retention_period": "P30M",
"svm": {
"name": "svm1",
Status: 201, Created
name |
string |
retention_period |
string |
svm |
"name": "string",
"svm": {
"name": "svm1",
Status: Default, Error
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
snaplock_retention_policy
name |
string |
retention_period |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
