REST API reference
Create an EBR policy for an SVM
POST /storage/snaplock/event-retention/policies
Introduced In: 9.7
Creates an Event Based Retention (EBR) policy for an SVM. The input parameter retention_period expects the duration in ISO 8601 format or infinite.
Required properties
  • name - Event retention policy name.
  • retention_period - Retention period of the EBR policy.
  • snaplock event-retention policy create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
name
string
Specifies the EBR policy name
retention_period
string
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively. For example "P10Y" represents a duration of 10 years. Similarly, a duration in hours, minutes is represented by "PTH", "PTM" respectively. The period string must contain only a single time element i.e. either years, months, days, hours or minutes. A duration which combines different periods is not supported, example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the retention period field also accepts the strings "infinite" and "unspecified".
svm
svm
Example request
  "name": "string",
  "retention_period": "P30M",
  "svm": {
    "name": "svm1",
Status: 201, Created
name
string
retention_period
string
svm
svm
  "name": "string",
  "svm": {
    "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response codes
Error code Description
918253
Incorrect format for the retention period, duration must be in the ISO-8601 format or infinite or unspecified.
13763280
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation.
13763402
Policy name already exists.
string
svm
name
string
uuid
string
snaplock_retention_policy
name
string
retention_period
string
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
