REST API reference
Delete a broadcast domain
Deletes a broadcast domain to remove its configuration and associated network settings from the system. This operation is typically used when the broadcast domain is no longer required or needs to be reconfigured.
HTTP method and endpoint
DELETE /network/ethernet/broadcast-domains/{uuid}
Introduced in
ONTAP 9.6
  • network port broadcast-domain delete
uuid
string
path
True
Broadcast domain UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1967103
A broadcast domain with ports cannot be deleted.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
