Delete a broadcast domain
DELETE /network/ethernet/broadcast-domains/{uuid}
Introduced In: 9.6
Deletes a broadcast domain.
Related ONTAP commands
network port broadcast-domain delete
uuid |
string |
path |
True |
Broadcast domain UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1967103 |
A broadcast domain with ports cannot be deleted. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
