REST API reference
Delete a broadcast domain
Deletes a broadcast domain. Use this endpoint when you need to remove a broadcast domain from the network configuration.
HTTP method and endpoint
DELETE /network/ethernet/broadcast-domains/{uuid}
Introduced in
ONTAP 9.6
  • network port broadcast-domain delete
uuid
string
path
True
Broadcast domain UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1967103
A broadcast domain with ports cannot be deleted.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
