      Delete an NDMP session
DELETE /protocols/ndmp/sessions/{owner.uuid}/{session.id}
Introduced In: 9.7
Deletes a specific NDMP session.
Related ONTAP commands
vserver services ndmp kill -
system services ndmp kill
Learn more
owner.uuid  |
string  |
path  |
True  |
NDMP node UUID  |
session.id  |
string  |
path  |
True  |
Session identifier  |
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error code | Description |
68812802  |
The UUID is not valid.  |
68812803  |
Failed to get the SVM name from the specified SVM UUID.  |
68812804  |
Failed to get the node name from the specified node UUID.  |
68812805  |
Failed to obtain the NDMP mode of operation.  |
68812806  |
UUID and Session ID are required.  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
