Delete an NDMP session
DELETE /protocols/ndmp/sessions/{owner.uuid}/{session.id}
Introduced In: 9.7
Deletes a specific NDMP session.
Related ONTAP commands
vserver services ndmp kill -
system services ndmp kill
Learn more
owner.uuid |
string |
path |
True |
NDMP node UUID |
session.id |
string |
path |
True |
Session identifier |
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error code | Description |
68812802 |
The UUID is not valid. |
68812803 |
Failed to get the SVM name from the specified SVM UUID. |
68812804 |
Failed to get the node name from the specified node UUID. |
68812805 |
Failed to obtain the NDMP mode of operation. |
68812806 |
UUID and Session ID are required. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
