REST API reference
Delete an NDMP session
Deletes a specific NDMP session to terminate its current operations and free resources.
HTTP method and endpoint
DELETE /protocols/ndmp/sessions/{owner.uuid}/{session.id}
Introduced in
ONTAP 9.7
  • vserver services ndmp kill
  • system services ndmp kill
owner.uuid
string
path
True
NDMP node UUID
session.id
string
path
True
Session identifier
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code Description
68812802
The UUID is not valid.
68812803
Failed to get the SVM name from the specified SVM UUID.
68812804
Failed to get the node name from the specified node UUID.
68812805
Failed to obtain the NDMP mode of operation.
68812806
UUID and Session ID are required.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
