REST API reference
Delete the LDAP configuration for the cluster
DELETE /security/authentication/cluster/ldap
Introduced In: 9.6
Deletes the LDAP configuration of the cluster.
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
