REST API reference
Delete the LDAP configuration for the cluster
Deletes the LDAP configuration for the cluster, removing its association with the current settings. This action is typically used when reconfiguring or retiring LDAP services.
HTTP method and endpoint
DELETE /security/authentication/cluster/ldap
Introduced in
ONTAP 9.6
Usage notes
Deletes the LDAP configuration of the cluster.
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
