Delete the LDAP configuration for the cluster
Deletes the LDAP configuration for the cluster, removing its association with the current settings. This action is typically used when reconfiguring or retiring LDAP services.
HTTP method and endpoint
DELETE /security/authentication/cluster/ldap
Introduced in
ONTAP 9.6
Usage notes
Deletes the LDAP configuration of the cluster.
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
