REST API reference
Delete a role
Deletes a specified role from the system. Use this to manage and remove roles that are no longer needed in your security configuration.
HTTP method and endpoint
DELETE /security/roles/{owner.uuid}/{name}
Introduced in
ONTAP 9.6
Required parameters
  • name - Name of the role to be deleted.
  • owner.uuid - UUID of the SVM housing the role.
  • security login rest-role delete
  • security login role delete
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name to be deleted.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1263347
Cannot modify pre-defined roles.
5636169
Specified URI path is invalid or not supported. Resource-qualified endpoints are not supported.
5636170
URI does not exist.
5636172
User accounts detected with this role assigned. Update or delete those accounts before deleting this role.
5636173
Features require an effective cluster version of 9.6 or later.
5636184
Expanded REST roles for granular resource control feature is currently disabled.
5636185
The specified UUID was not found.
5636186
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later.
13434890
Vserver-ID failed for Vserver roles.
13434893
The SVM does not exist.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
