REST API reference
Delete a role
DELETE /security/roles/{owner.uuid}/{name}
Introduced In: 9.6
Deletes the specified role.
Required parameters
  • name - Name of the role to be deleted.
  • owner.uuid - UUID of the SVM housing the role.
  • security login rest-role delete
  • security login role delete
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name to be deleted.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1263347
Cannot modify pre-defined roles.
5636169
Specified URI path is invalid or not supported. Resource-qualified endpoints are not supported.
5636170
URI does not exist.
5636172
User accounts detected with this role assigned. Update or delete those accounts before deleting this role.
5636173
Features require an effective cluster version of 9.6 or later.
5636184
Expanded REST roles for granular resource control feature is currently disabled.
5636185
The specified UUID was not found.
5636186
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later.
5636245
Failed to delete the role because it is part of the group role-mapping configuration.
5636246
Failed to delete the rest role because it is part of the group role-mapping configuration.
5636247
Failed to delete the rest role because it is part of the external-role-mapping configuration.
5636249
Failed to delete the role because it is part of the external-role-mapping configuration.
5636259
The specified child AIDE object was not found within the specified parent AIDE object.
5636261
The specified grandchild AIDE object was not found within the specified child AIDE object that belongs to the specified parent AIDE object.</personalities>
13434890
Vserver-ID failed for Vserver roles.
13434893
The SVM does not exist.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
