Delete a role
Deletes a specified role, removing its access permissions and configurations from the system. This operation is typically performed when a role is no longer needed or requires modification of its associated privileges.
HTTP method and endpoint
DELETE /security/roles/{owner.uuid}/{name}
Introduced in
ONTAP 9.6
Required parameters
name- Name of the role to be deleted. -
owner.uuid- UUID of the SVM housing the role.
Related ONTAP commands
security login rest-role delete -
security login role delete
owner.uuid |
string |
path |
True |
Role owner UUID |
name |
string |
path |
True |
Role name to be deleted. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1263347 |
Cannot modify pre-defined roles. |
5636169 |
Specified URI path is invalid or not supported. Resource-qualified endpoints are not supported. |
5636170 |
URI does not exist. |
5636172 |
User accounts detected with this role assigned. Update or delete those accounts before deleting this role. |
5636173 |
Features require an effective cluster version of 9.6 or later. |
5636184 |
Expanded REST roles for granular resource control feature is currently disabled. |
5636185 |
The specified UUID was not found. |
5636186 |
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later. |
5636245 |
Failed to delete the role because it is part of the group role-mapping configuration. |
5636246 |
Failed to delete the rest role because it is part of the group role-mapping configuration. |
5636247 |
Failed to delete the rest role because it is part of the external-role-mapping configuration. |
5636249 |
Failed to delete the role because it is part of the external-role-mapping configuration. |
13434890 |
Vserver-ID failed for Vserver roles. |
13434893 |
The SVM does not exist. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
