REST API reference
Deletes a specific file clone token
delete specific clone token
# the api:
/api/storage/file/clone/tokens/{nodeuuid}/{tokenuuid}
# the call:
curl -x delete "https://<mgmt_ip>/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/909c42ce-a74b-11eb-bd86-0050568ec7ae"
# the successful response is empty body
learn more
  • [doc /storage/file/clone]
DELETE /storage/file/clone/tokens/{node.uuid}/{uuid}
Introduced In: 9.10
Deletes a specific file clone token.
  • volume file clone token delete
Delete specific clone token.
# The API:
/api/storage/file/clone/tokens/{node.uuid}/{token.uuid}
# The call:
curl -X DELETE "https://<mgmt_ip>/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/909c42ce-a74b-11eb-bd86-0050568ec7ae"
# The successful response is empty body.
Learn More
  • [DOC /storage/file/clone]
node.uuid
string
path
True
Node UUID
uuid
string
path
True
Token UUID
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
