REST API reference
Delete a specific file clone token
DELETE /storage/file/clone/tokens/{node.uuid}/{uuid}
Introduced In: 9.10
Deletes a specific file clone token.
  • volume file clone token delete
Delete specific clone token.
# The API:
/api/storage/file/clone/tokens/{node.uuid}/{token.uuid}
# The call:
curl -X DELETE "https://<mgmt_ip>/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/909c42ce-a74b-11eb-bd86-0050568ec7ae"
# The successful response is empty body.
Learn More
  • [DOC /storage/file/clone]
node.uuid
string
path
True
Node UUID
uuid
string
path
True
Token UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
13565958
Failed to get information about token uuid for node node.name.
13565961
Failed to delete token for node node.name.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
