Delete a specific file clone token
DELETE /storage/file/clone/tokens/{node.uuid}/{uuid}
Introduced In: 9.10
Deletes a specific file clone token.
Related Ontap command
volume file clone token delete
Delete specific clone token.
# The API:
/api/storage/file/clone/tokens/{node.uuid}/{token.uuid}
# The call:
curl -X DELETE "https://<mgmt_ip>/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/909c42ce-a74b-11eb-bd86-0050568ec7ae"
# The successful response is empty body.
Learn More
DOC /storage/file/clone]
node.uuid |
string |
path |
True |
Node UUID |
uuid |
string |
path |
True |
Token UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13565958 |
Failed to get information about token |
13565961 |
Failed to delete token for node |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
