Delete a QoS policy
DELETE /storage/qos/policies/{uuid}
Introduced In: 9.6
Deletes a QoS policy. All QoS workloads associated with the policy are removed.
Related ONTAP commands
qos policy-group delete -
qos adaptive-policy-group delete
uuid |
string |
path |
True |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
