Delete a QoS policy
Deletes a QoS policy to remove it and all associated QoS workloads, streamlining your storage resource management.
HTTP method and endpoint
DELETE /storage/qos/policies/{uuid}
Introduced in
ONTAP 9.6
Usage notes
All QoS workloads associated with the policy are removed.
Related ONTAP commands
qos policy-group delete -
qos adaptive-policy-group delete
uuid |
string |
path |
True |
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
