REST API reference
Delete a QoS policy
Deletes a QoS policy, which removes all associated QoS workloads.
HTTP method and endpoint
DELETE /storage/qos/policies/{uuid}
Introduced in
ONTAP 9.6
Usage notes
All QoS workloads associated with the policy are removed.
  • qos policy-group delete
  • qos adaptive-policy-group delete
uuid
string
path
True
  • Introduced in: 9.8
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
