REST API reference
Deletes a qos policy all qos workloads associated with the policy are removed
  • qos adaptive-policy-group delete
learn more
  • [doc /storage/qos/policies](#docs-storage-storage_qos_policies)
DELETE /storage/qos/policies/{policy.uuid}
Deletes a QoS policy. All QoS workloads associated with the policy are removed.
  • qos policy-group delete
policy.uuid
string
path
True
return_timeout
integer
query
False
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
