Delete an SVM
Deletes a storage virtual machine (SVM) to remove it from your ONTAP environment. This operation is typically performed when an SVM is no longer needed or when its resources need to be reallocated.
HTTP method and endpoint
DELETE /svm/svms/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes an SVM. As a prerequisite, SVM objects must be deleted first. SnapMirror relationships must be deleted and data volumes must be offline and deleted.
The number of parallel SVMs that can be created must not be greater than five.
If a sixth SVM POST request is issued, the following error message is generated: "Maximum allowed SVM jobs exceeded. Wait for the existing SVM jobs to complete and try again."
Related ONTAP commands
vserver delete
Example
Deleting an individual SVM in the cluster.
DELETE "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485"
Learn more
uuid |
string |
path |
True |
Filter by UUID |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
13434894 |
Maximum allowed SVM jobs exceeded. Wait and retry. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
