Delete an SVM
Deletes an SVM to remove it from your environment once all associated objects and relationships are cleared.
HTTP method and endpoint
DELETE /svm/svms/{uuid}
Introduced in
ONTAP 9.6
Usage notes
As a prerequisite, SVM objects must be deleted first. SnapMirror relationships must be deleted and data volumes must be offline and deleted.
The number of parallel SVMs that can be created must not be greater than five.
If a sixth SVM POST request is issued, the following error message is generated: "Maximum allowed SVM jobs exceeded. Wait for the existing SVM jobs to complete and try again."
Related ONTAP commands
vserver delete
Example
Deleting an individual SVM in the cluster.
DELETE "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485"
Learn more
uuid |
string |
path |
True |
Filter by UUID |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
13434894 |
Maximum allowed SVM jobs exceeded. Wait and retry. |
2621525 |
SVM cannot be deleted as it is associated with an Active Directory configured CIFS server. Delete the CIFS server using "cifs delete" and retry the operation. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
