REST API reference
Delete an SVM
Deletes an SVM to remove it from your environment once all associated objects and relationships are cleared.
HTTP method and endpoint
DELETE /svm/svms/{uuid}
Introduced in
ONTAP 9.6
Usage notes
As a prerequisite, SVM objects must be deleted first. SnapMirror relationships must be deleted and data volumes must be offline and deleted.
  • The number of parallel SVMs that can be created must not be greater than five.
  • If a sixth SVM POST request is issued, the following error message is generated: "Maximum allowed SVM jobs exceeded. Wait for the existing SVM jobs to complete and try again."
  • vserver delete
Example
Deleting an individual SVM in the cluster.
DELETE "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485"
Learn more
uuid
string
path
True
Filter by UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error codes Description
13434894
Maximum allowed SVM jobs exceeded. Wait and retry.
2621525
SVM cannot be deleted as it is associated with an Active Directory configured CIFS server. Delete the CIFS server using "cifs delete" and retry the operation.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
