REST API reference
Retrieves a host cache setting for a given svm
learn more
  • [doc /name-services/cache/host/settings](#docs-name-services-name-services_cache_host_settings)
GET /name-services/cache/host/settings/{svm.uuid}
Introduced In: 9.11
Retrieves a host cache setting for a given SVM.
  • vserver services name-service cache hosts settings show
svm.uuid
string
path
True
SVM UUID.
enabled
boolean
query
False
Filter by enabled
ttl
string
query
False
Filter by ttl
negative_cache_enabled
boolean
query
False
Filter by negative_cache_enabled
dns_ttl_enabled
boolean
query
False
Filter by dns_ttl_enabled
svm.name
string
query
False
Filter by svm.name
negative_ttl
string
query
False
Filter by negative_ttl
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
dns_ttl_enabled
boolean
Specifies whether TTL is based on the DNS or host settings. If enabled, TTL from DNS is used.
enabled
boolean
Indicates whether or not the cache is enabled.
boolean
Indicates whether or not the negative cache is enabled.
negative_ttl
string
Specifies negative Time to Live, in ISO 8601 format.
svm
svm
ttl
string
Specifies Time to Live (TTL), in ISO 8601 format.
      "href": "/api/resourcelink"
  "dns_ttl_enabled": 1,
  "negative_ttl": "PT5M",
  "svm": {
    "name": "svm1",
  "ttl": "PT24H"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
