Retrieve a host cache setting for an SVM
GET /name-services/cache/host/settings/{uuid}
Introduced In: 9.14
Retrieves a host cache setting for a given SVM.
Related ONTAP commands
vserver services name-service cache hosts settings show
Learn more
uuid  |
string  |
path  |
True  |
UUID for the host record.  |
ttl  |
string  |
query  |
False  |
Filter by ttl  |
negative_cache_enabled  |
boolean  |
query  |
False  |
Filter by negative_cache_enabled  |
negative_ttl  |
string  |
query  |
False  |
Filter by negative_ttl  |
svm.name  |
string  |
query  |
False  |
Filter by svm.name  |
svm.uuid  |
string  |
query  |
False  |
Filter by svm.uuid  |
dns_ttl_enabled  |
boolean  |
query  |
False  |
Filter by dns_ttl_enabled  |
enabled  |
boolean  |
query  |
False  |
Filter by enabled  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
dns_ttl_enabled  |
boolean  |
Specifies whether TTL is based on the DNS or host settings. If enabled, TTL from DNS is used.  |
enabled  |
boolean  |
Indicates whether or not the cache is enabled.  |
boolean  |
Indicates whether or not the negative cache is enabled.  |
negative_ttl  |
string  |
Specifies negative Time to Live, in ISO 8601 format.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
ttl  |
string  |
Specifies Time to Live (TTL), in ISO 8601 format.  |
uuid  |
string  |
      "href": "/api/resourcelink"
  "dns_ttl_enabled": 1,
  "negative_ttl": "PT5M",
  "svm": {
    "name": "svm1",
  "ttl": "PT24H",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
