Retrieve a host cache setting for an SVM
Retrieves a host cache setting for a specific SVM to review its current configuration. This can help you understand how the host cache is set up for efficient name resolution within the SVM.
HTTP method and endpoint
GET /name-services/cache/host/settings/{uuid}
Introduced in
ONTAP 9.14
Usage notes
Retrieves a host cache setting for a given SVM.
Related ONTAP commands
vserver services name-service cache hosts settings show
Learn more
uuid |
string |
path |
True |
UUID for the host record. |
negative_ttl |
string |
query |
False |
Filter by negative_ttl |
dns_ttl_enabled |
boolean |
query |
False |
Filter by dns_ttl_enabled |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
negative_cache_enabled |
boolean |
query |
False |
Filter by negative_cache_enabled |
ttl |
string |
query |
False |
Filter by ttl |
enabled |
boolean |
query |
False |
Filter by enabled |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
dns_ttl_enabled |
boolean |
Specifies whether TTL is based on the DNS or host settings. If enabled, TTL from DNS is used. |
enabled |
boolean |
Indicates whether or not the cache is enabled. |
boolean |
Indicates whether or not the negative cache is enabled. |
negative_ttl |
string |
Specifies negative Time to Live, in ISO 8601 format. |
svm |
ttl |
string |
Specifies Time to Live (TTL), in ISO 8601 format. |
uuid |
string |
"href": "/api/resourcelink"
"dns_ttl_enabled": 1,
"negative_ttl": "PT5M",
"svm": {
"name": "svm1",
"ttl": "PT24H",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
