REST API reference
Retrieves the details of an ethernet switch
learn more
  • [doc /network/ethernet/switches](#docs-networking-network_ethernet_switches)
GET /network/ethernet/switches/{name}
Introduced In: 9.8
Retrieves the details of an Ethernet switch.
  • system switch ethernet show
name
string
path
True
Name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
address
string
IP Address.
discovered
boolean
Discovered By ONTAP CDP/LLDP
  • readOnly: 1
  • Introduced in: 9.8
  • x-nullable: true
model
string
Model Number.
monitoring
monitoring
name
string
Name.
network
string
Switch Network.
serial_number
string
Serial Number.
snmp
snmp
version
string
Software Version.
      "href": "/api/resourcelink"
  "address": "string",
  "model": "string",
  "monitoring": {
    "reason": "string"
  "name": "string",
  "network": "string",
  "serial_number": "string",
  "snmp": {
    "user": "string",
    "version": "string"
  "version": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
monitoring
enabled
boolean
Enable Health Monitoring.
monitored
boolean
Is Monitored.
reason
string
Reason For Not Monitoring.
snmp
user
string
Community String or SNMPv3 Username.
version
string
SNMP Version.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
