REST API reference
Retrieve Ethernet switch details
Accesses Ethernet switch details to review their configuration and status within your network environment.
HTTP method and endpoint
GET /network/ethernet/switches/{name}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the details of an Ethernet switch.
  • system switch ethernet show
name
string
path
True
Name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
address
string
IP Address.
discovered
boolean
Discovered By ONTAP CDP/LLDP
  • readOnly: 1
  • Introduced in: 9.8
  • x-nullable: true
model
string
Model Number.
monitoring
monitoring
name
string
Name.
network
string
Switch Network.
rcf_version
string
The switch reference configuration file (RCF) version.
role
string
Switch role based on the interface configurations. Using '+' to combine multiple roles. Available role types are: cluster, multicluster, storage, multistorage, metrocluster.
serial_number
string
Serial Number.
snmp
snmp
version
string
Software Version.
      "href": "/api/resourcelink"
  "address": "string",
  "model": "string",
  "monitoring": {
    "reason": "string"
  "name": "string",
  "network": "string",
  "rcf_version": "RCF NX9336C-FX2 v1.13 1-CLUSTER",
  "role": [
    "cluster+storage"
  "serial_number": "string",
  "snmp": {
    "user": "string",
    "version": "string"
  "version": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
monitoring
enabled
boolean
Enable Health Monitoring.
monitored
boolean
Is Monitored.
reason
string
Reason For Not Monitoring.
snmp
user
string
Community String or SNMPv3 Username.
version
string
SNMP Version.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
