Retrieve Ethernet switch details
Accesses Ethernet switch details to review their configuration and status within your network environment.
HTTP method and endpoint
GET /network/ethernet/switches/{name}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the details of an Ethernet switch.
Related ONTAP commands
system switch ethernet show
Learn more
name |
string |
path |
True |
Name |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
address |
string |
IP Address. |
discovered |
boolean |
Discovered By ONTAP CDP/LLDP
model |
string |
Model Number. |
monitoring |
name |
string |
Name. |
network |
string |
Switch Network. |
rcf_version |
string |
The switch reference configuration file (RCF) version. |
role |
string |
Switch role based on the interface configurations. Using '+' to combine multiple roles. Available role types are: cluster, multicluster, storage, multistorage, metrocluster. |
serial_number |
string |
Serial Number. |
snmp |
version |
string |
Software Version. |
"href": "/api/resourcelink"
"address": "string",
"model": "string",
"monitoring": {
"reason": "string"
"name": "string",
"network": "string",
"rcf_version": "RCF NX9336C-FX2 v1.13 1-CLUSTER",
"role": [
"cluster+storage"
"serial_number": "string",
"snmp": {
"user": "string",
"version": "string"
"version": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
monitoring
enabled |
boolean |
Enable Health Monitoring. |
monitored |
boolean |
Is Monitored. |
reason |
string |
Reason For Not Monitoring. |
snmp
user |
string |
Community String or SNMPv3 Username. |
version |
string |
SNMP Version. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
