REST API reference
Retrieves the details of all ip interfaces
GET /network/ip/interfaces
Introduced In: 9.6
Retrieves the details of all IP interfaces.
  • network interface show
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
location.failover
string
query
False
Filter by location.failover
location.home_port.name
string
query
False
Filter by location.home_port.name
location.home_port.node.name
string
query
False
Filter by location.home_port.node.name
location.home_port.uuid
string
query
False
Filter by location.home_port.uuid
location.auto_revert
boolean
query
False
Filter by location.auto_revert
location.home_node.uuid
string
query
False
Filter by location.home_node.uuid
location.home_node.name
string
query
False
Filter by location.home_node.name
location.port.name
string
query
False
Filter by location.port.name
location.port.node.name
string
query
False
Filter by location.port.node.name
location.port.uuid
string
query
False
Filter by location.port.uuid
location.is_home
boolean
query
False
Filter by location.is_home
location.node.uuid
string
query
False
Filter by location.node.uuid
location.node.name
string
query
False
Filter by location.node.name
services
string
query
False
Filter by services
uuid
string
query
False
Filter by uuid
enabled
boolean
query
False
Filter by enabled
probe_port
integer
query
False
Filter by probe_port
  • Introduced in: 9.10
scope
string
query
False
Filter by scope
dns_zone
string
query
False
Filter by dns_zone
  • Introduced in: 9.9
statistics.status
string
query
False
Filter by statistics.status
  • Introduced in: 9.8
statistics.timestamp
string
query
False
Filter by statistics.timestamp
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
ddns_enabled
boolean
query
False
Filter by ddns_enabled
subnet.name
string
query
False
Filter by subnet.name
  • Introduced in: 9.11
subnet.uuid
string
query
False
Filter by subnet.uuid
state
string
query
False
Filter by state
ipspace.name
string
query
False
Filter by ipspace.name
ipspace.uuid
string
query
False
Filter by ipspace.uuid
metric.duration
string
query
False
Filter by metric.duration
metric.throughput.total
integer
query
False
Filter by metric.throughput.total
metric.throughput.read
integer
query
False
Filter by metric.throughput.read
metric.throughput.write
integer
query
False
Filter by metric.throughput.write
metric.status
string
query
False
Filter by metric.status
metric.timestamp
string
query
False
Filter by metric.timestamp
ip.netmask
string
query
False
Filter by ip.netmask
ip.family
string
query
False
Filter by ip.family
ip.address
string
query
False
Filter by ip.address
name
string
query
False
Filter by name
vip
boolean
query
False
Filter by vip
service_policy.uuid
string
query
False
Filter by service_policy.uuid
service_policy.name
string
query
False
Filter by service_policy.name
rdma_protocols
string
query
False
Filter by rdma_protocols
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[ip_interface]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "dns_zone": "storage.company.com",
      "fail_if_subnet_conflicts": true,
      "ip": {
        "address": "10.10.10.7",
        "family": "string",
        "netmask": "24"
      "ipspace": {
        "name": "exchange",
      "location": {
        "failover": "string",
        "home_node": {
          "name": "node1",
        "home_port": {
          "name": "e1b",
          "node": {
            "name": "node1"
        "node": {
          "name": "node1",
        "port": {
          "name": "e1b",
          "node": {
            "name": "node1"
      "metric": {
        "duration": "PT15S",
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
        "timestamp": "2017-01-25 11:20:13 +0000"
      "name": "dataLif1",
      "probe_port": 64001,
      "rdma_protocols": [
        "roce"
      "scope": "string",
      "service_policy": {
        "name": "default-intercluster",
      "services": [
        "data_nfs"
      "state": "string",
      "statistics": {
        "status": "ok",
        "throughput_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
      "subnet": {
        "name": "subnet1",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ip_info
IP information
address
string
IPv4 or IPv6 address
family
string
IPv4 or IPv6
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
ipspace
Either the UUID or name must be supplied on POST for cluster-scoped objects.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
broadcast_domain
_links
_links
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
Broadcast domain UUID
home_node
_links
_links
name
string
uuid
string
node
name
string
Name of node on which the port is located.
home_port
_links
_links
name
string
node
node
uuid
string
node
_links
_links
name
string
uuid
string
port
_links
_links
name
string
node
node
uuid
string
location
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node. For PATCH, set is_home to true to revert a LIF back to its home port.
auto_revert
boolean
failover
string
Policy that defines where an interface is permitted to move on failover. The policy named “default” implements the recommended best practice for NAS LIFs on the current platform and cluster, and was known as “system_defined” in the CLI.
home_node
home_node
home_port
home_port
is_home
boolean
node
node
port
port
throughput
The rate of throughput bytes per second observed at the interface.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
metric
The most recent sample of I/O metrics for the interface.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
service_policy
_links
_links
name
string
uuid
string
throughput_raw
Throughput bytes observed at the interface. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
The real time I/O statistics for the interface.
status
string
throughput_raw
throughput_raw
timestamp
string
ip_subnet_reference
A named subnet. Either UUID or name can be supplied on input.
_links
_links
name
string
The name of the subnet. If only the name is provided, the IPspace scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the subnet.
svm
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST.
_links
_links
name
string
The name of the SVM.
uuid
string
ip_interface
_links
_links
ddns_enabled
boolean
Indicates whether or not dynamic DNS updates are enabled. Defaults to true if the interface supports "data_nfs" or "data_cifs" services, otherwise false.
dns_zone
string
Fully qualified DNS zone name
enabled
boolean
The administrative state of the interface.
ip
ip_info
IP information
ipspace
ipspace
location
location
metric
metric
name
string
Interface name
probe_port
integer
Probe port for Cloud load balancer
rdma_protocols
array[string]
Supported RDMA offload protocols
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
service_policy
service_policy
services
array[string]
The services associated with the interface.
state
string
The operational state of the interface.
statistics
statistics
subnet
ip_subnet_reference
svm
svm
uuid
string
The UUID that uniquely identifies the interface.
vip
boolean
True for a VIP interface, whose location is announced via BGP.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
