Retrieve all IP interface details
Obtains comprehensive information about each IP interface, which aids in network management and troubleshooting tasks.
HTTP method and endpoint
GET /network/ip/interfaces
Introduced in
ONTAP 9.6
Usage notes
Retrieves the details of all IP interfaces.
Related ONTAP Commands
network interface show
ipspace.name |
string |
query |
False |
Filter by ipspace.name |
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid |
subnet.uuid |
string |
query |
False |
Filter by subnet.uuid
subnet.name |
string |
query |
False |
Filter by subnet.name
name |
string |
query |
False |
Filter by name |
rdma_protocols |
string |
query |
False |
Filter by rdma_protocols
probe_port |
integer |
query |
False |
Filter by probe_port
services |
string |
query |
False |
Filter by services |
ddns_enabled |
boolean |
query |
False |
Filter by ddns_enabled
enabled |
boolean |
query |
False |
Filter by enabled |
location.auto_revert |
boolean |
query |
False |
Filter by location.auto_revert |
location.home_node.uuid |
string |
query |
False |
Filter by location.home_node.uuid |
location.home_node.name |
string |
query |
False |
Filter by location.home_node.name |
location.node.uuid |
string |
query |
False |
Filter by location.node.uuid |
location.node.name |
string |
query |
False |
Filter by location.node.name |
location.port.node.name |
string |
query |
False |
Filter by location.port.node.name |
location.port.name |
string |
query |
False |
Filter by location.port.name |
location.port.uuid |
string |
query |
False |
Filter by location.port.uuid |
location.failover |
string |
query |
False |
Filter by location.failover |
location.is_home |
boolean |
query |
False |
Filter by location.is_home |
location.home_port.node.name |
string |
query |
False |
Filter by location.home_port.node.name |
location.home_port.name |
string |
query |
False |
Filter by location.home_port.name |
location.home_port.uuid |
string |
query |
False |
Filter by location.home_port.uuid |
statistics.status |
string |
query |
False |
Filter by statistics.status
statistics.timestamp |
string |
query |
False |
Filter by statistics.timestamp
statistics.throughput_raw.read |
integer |
query |
False |
Filter by statistics.throughput_raw.read
statistics.throughput_raw.total |
integer |
query |
False |
Filter by statistics.throughput_raw.total
statistics.throughput_raw.write |
integer |
query |
False |
Filter by statistics.throughput_raw.write
vip |
boolean |
query |
False |
Filter by vip |
dns_zone |
string |
query |
False |
Filter by dns_zone
uuid |
string |
query |
False |
Filter by uuid |
ip.family |
string |
query |
False |
Filter by ip.family |
ip.netmask |
string |
query |
False |
Filter by ip.netmask |
ip.address |
string |
query |
False |
Filter by ip.address |
state |
string |
query |
False |
Filter by state |
scope |
string |
query |
False |
Filter by scope |
service_policy.uuid |
string |
query |
False |
Filter by service_policy.uuid |
service_policy.name |
string |
query |
False |
Filter by service_policy.name |
metric.status |
string |
query |
False |
Filter by metric.status
metric.timestamp |
string |
query |
False |
Filter by metric.timestamp
metric.duration |
string |
query |
False |
Filter by metric.duration
metric.throughput.read |
integer |
query |
False |
Filter by metric.throughput.read
metric.throughput.total |
integer |
query |
False |
Filter by metric.throughput.total
metric.throughput.write |
integer |
query |
False |
Filter by metric.throughput.write
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
recommend.svm.uuid |
string |
query |
False |
The UUID of an existing SVM for which to recommend IP interfaces.
recommend.svm.name |
string |
query |
False |
The name of an existing SVM for which to recommend IP interfaces.
recommend.ipspace.uuid |
string |
query |
False |
The UUID of an existing IPspace for which to recommend IP interfaces.
recommend.ipspace.name |
string |
query |
False |
The name of an existing IPspace for which to recommend IP interfaces.
recommend.service_policy.uuid |
string |
query |
False |
The UUID of an IP service policy for which to recommend IP interfaces.
recommend.service_policy.name |
string |
query |
False |
The name of an IP service policy for which to recommend IP interfaces.
recommend.ip.family |
string |
query |
False |
The name of an IP Address Family for which to recommend IP interfaces. Unless ipv6 is specified, the default value is ipv4.
recommend.location.broadcast_domain.uuid |
string |
query |
False |
The UUID of an existing broadcast domain for which to recommend IP interfaces.
recommend.location.broadcast_domain.name |
string |
query |
False |
The name of an existing broadcast domain for which to recommend IP interfaces.
recommend.subnet.uuid |
string |
query |
False |
The UUID of an existing subnet for which to recommend IP interfaces.
recommend.subnet.name |
string |
query |
False |
The name of an existing subnet for which to recommend IP interfaces.
recommend.interfaces_per_node |
integer |
query |
False |
The number of IP interfaces to recommend per node.
recommend.location.port.rdma_protocol |
string |
query |
False |
The RDMA protocol supported on locations for which to recommend IP interfaces.
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
recommend |
Response properties specific to the LIF recommendation functionality. |
records |
array[ip_interface] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"recommend": {
"messages": [
"records": [
"dns_zone": "storage.company.com",
"fail_if_subnet_conflicts": true,
"ip": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"ipspace": {
"name": "Default",
"location": {
"failover": "string",
"home_node": {
"name": "node1",
"home_port": {
"name": "e1b",
"node": {
"name": "node1"
"node": {
"name": "node1",
"port": {
"name": "e1b",
"node": {
"name": "node1"
"metric": {
"duration": "PT15S",
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 06:20:13 -0500"
"name": "dataLif1",
"probe_port": 64001,
"rdma_protocols": [
"roce"
"scope": "string",
"service_policy": {
"name": "default-intercluster",
"services": [
"data_nfs"
"state": "string",
"statistics": {
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"subnet": {
"name": "subnet1",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
53282769 |
Not all nodes support enabling the LIF recommendations feature. |
53282770 |
No matching subnets are configured in IPspace. |
53282772 |
Not enough available IPs in subnet. |
53282773 |
Not enough locations available on node for subnet. |
53282774 |
The specified SVM UUID is invalid. |
53282775 |
The specified SVM name is invalid. |
53282776 |
The specified SVM name and UUID do not match. |
53282777 |
The specified SVM does not exist in the IPspace. |
53282778 |
53282779 |
The specified IPspace UUID is invalid. |
53282780 |
The specified IPspace name is invalid. |
53282781 |
The specified IPspace UUID and name do not match. |
53282782 |
The specified service policy UUID does not exist. |
53282783 |
THe specified service policy UUID and name do not match. |
53282784 |
The specified service policy does not exist in the SVM. |
53282785 |
The specified service policy does not exist in the IPspace. |
53282786 |
The specified broadcast domain does not exist. |
53282787 |
The specified broadcast domain UUID and name do not match. |
53282788 |
The specified broadcast domain UUID does not exist in the IPspace. |
53282789 |
The specified broadcast domain name does not exist in the IPspace. |
53282790 |
The specified subnet UUID does not exist. |
53282791 |
The specified subnet UUID and name do not match. |
53282792 |
The specified subnet does not exist in the IPspace. |
53282793 |
The specified subnet does not match the specified broadcast domain. |
53282794 |
The specified subnet name does not exist in the IPspace. |
53282795 |
The specified subnet name does not exist in the broadcast domain. |
53282796 |
The specified SVM has a type that is not supported. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
ip_interface_recommend_message
recommend
messages |
Messages describing the results of a LIF recommendation request. |
_links
self |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
ipspace
Either the UUID or name must be supplied on POST for cluster-scoped objects.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
broadcast_domain
Broadcast domain UUID along with a readable name.
_links |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
home_node
_links |
name |
string |
uuid |
string |
node
name |
string |
Name of node on which the port is located. |
home_port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links |
name |
string |
node |
uuid |
string |
node
_links |
name |
string |
uuid |
string |
port
_links |
name |
string |
node |
uuid |
string |
location
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node. For PATCH, set is_home to true to revert a LIF back to its home port.
auto_revert |
boolean |
failover |
string |
Policy that defines where an interface is permitted to move on failover. The policy named “default” implements the recommended best practice for NAS LIFs on the current platform and cluster, and was known as “system_defined” in the CLI. |
home_node |
home_port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
is_home |
boolean |
node |
port |
throughput
The rate of throughput bytes per second observed at the interface.
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
metric
The most recent sample of I/O metrics for the interface.
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the interface. |
timestamp |
string |
The timestamp of the performance data. |
service_policy
_links |
name |
string |
uuid |
string |
throughput_raw
Throughput bytes observed at the interface. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
The real time I/O statistics for the interface.
status |
string |
throughput_raw |
Throughput bytes observed at the interface. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
ip_subnet_reference
A named subnet. Either UUID or name can be supplied on input.
_links |
name |
string |
The name of the subnet. If only the name is provided, the IPspace scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the subnet. |
svm
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST.
_links |
name |
string |
uuid |
string |
ip_interface
_links |
ddns_enabled |
boolean |
Indicates whether or not dynamic DNS updates are enabled. Defaults to true if the interface supports "data_nfs" or "data_cifs" services, otherwise false. |
dns_zone |
string |
Fully qualified DNS zone name |
enabled |
boolean |
The administrative state of the interface. |
ip |
IP information |
ipspace |
Either the UUID or name must be supplied on POST for cluster-scoped objects. |
location |
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node. For PATCH, set is_home to true to revert a LIF back to its home port. |
metric |
The most recent sample of I/O metrics for the interface. |
name |
string |
Interface name |
probe_port |
integer |
Probe port for Cloud load balancer |
rdma_protocols |
array[string] |
Supported RDMA offload protocols |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
service_policy |
services |
array[string] |
The services associated with the interface. |
state |
string |
The operational state of the interface. |
statistics |
The real time I/O statistics for the interface. |
subnet |
A named subnet. Either UUID or name can be supplied on input. |
svm |
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST. |
uuid |
string |
The UUID that uniquely identifies the interface. |
vip |
boolean |
True for a VIP interface, whose location is announced via BGP. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
