REST API reference
Retrieve all IP interface details
GET /network/ip/interfaces
Introduced In: 9.6
Retrieves the details of all IP interfaces.
  • network interface show
vip
boolean
query
False
Filter by vip
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
probe_port
integer
query
False
Filter by probe_port
  • Introduced in: 9.10
scope
string
query
False
Filter by scope
ipspace.name
string
query
False
Filter by ipspace.name
ipspace.uuid
string
query
False
Filter by ipspace.uuid
rdma_protocols
string
query
False
Filter by rdma_protocols
service_policy.uuid
string
query
False
Filter by service_policy.uuid
service_policy.name
string
query
False
Filter by service_policy.name
location.auto_revert
boolean
query
False
Filter by location.auto_revert
location.is_home
boolean
query
False
Filter by location.is_home
location.failover
string
query
False
Filter by location.failover
location.port.node.name
string
query
False
Filter by location.port.node.name
location.port.uuid
string
query
False
Filter by location.port.uuid
location.port.name
string
query
False
Filter by location.port.name
location.home_node.name
string
query
False
Filter by location.home_node.name
location.home_node.uuid
string
query
False
Filter by location.home_node.uuid
location.node.name
string
query
False
Filter by location.node.name
location.node.uuid
string
query
False
Filter by location.node.uuid
location.home_port.node.name
string
query
False
Filter by location.home_port.node.name
location.home_port.uuid
string
query
False
Filter by location.home_port.uuid
location.home_port.name
string
query
False
Filter by location.home_port.name
services
string
query
False
Filter by services
enabled
boolean
query
False
Filter by enabled
name
string
query
False
Filter by name
subnet.name
string
query
False
Filter by subnet.name
  • Introduced in: 9.11
subnet.uuid
string
query
False
Filter by subnet.uuid
state
string
query
False
Filter by state
statistics.timestamp
string
query
False
Filter by statistics.timestamp
  • Introduced in: 9.8
statistics.status
string
query
False
Filter by statistics.status
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
ip.family
string
query
False
Filter by ip.family
ip.address
string
query
False
Filter by ip.address
ip.netmask
string
query
False
Filter by ip.netmask
uuid
string
query
False
Filter by uuid
ddns_enabled
boolean
query
False
Filter by ddns_enabled
  • Introduced in: 9.9
metric.status
string
query
False
Filter by metric.status
metric.duration
string
query
False
Filter by metric.duration
metric.throughput.write
integer
query
False
Filter by metric.throughput.write
metric.throughput.read
integer
query
False
Filter by metric.throughput.read
metric.throughput.total
integer
query
False
Filter by metric.throughput.total
metric.timestamp
string
query
False
Filter by metric.timestamp
dns_zone
string
query
False
Filter by dns_zone
recommend.svm.uuid
string
query
False
The UUID of an existing SVM for which to recommend IP interfaces.
  • Introduced in: 9.16
recommend.svm.name
string
query
False
The name of an existing SVM for which to recommend IP interfaces.
recommend.ipspace.uuid
string
query
False
The UUID of an existing IPspace for which to recommend IP interfaces.
recommend.ipspace.name
string
query
False
The name of an existing IPspace for which to recommend IP interfaces.
recommend.service_policy.uuid
string
query
False
The UUID of an IP service policy for which to recommend IP interfaces.
recommend.service_policy.name
string
query
False
The name of an IP service policy for which to recommend IP interfaces.
  • Introduced in: 9.17
recommend.ip.family
string
query
False
The name of an IP Address Family for which to recommend IP interfaces. Unless ipv6 is specified, the default value is ipv4.
  • enum: ["ipv4", "ipv6"]
recommend.location.broadcast_domain.uuid
string
query
False
The UUID of an existing broadcast domain for which to recommend IP interfaces.
recommend.location.broadcast_domain.name
string
query
False
The name of an existing broadcast domain for which to recommend IP interfaces.
recommend.subnet.uuid
string
query
False
The UUID of an existing subnet for which to recommend IP interfaces.
recommend.subnet.name
string
query
False
The name of an existing subnet for which to recommend IP interfaces.
recommend.interfaces_per_node
integer
query
False
The number of IP interfaces to recommend per node.
recommend.location.port.rdma_protocol
string
query
False
The RDMA protocol supported on locations for which to recommend IP interfaces.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
recommend
recommend
Response properties specific to the LIF recommendation functionality.
records
array[ip_interface]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "recommend": {
    "messages": [
  "records": [
      "dns_zone": "storage.company.com",
      "fail_if_subnet_conflicts": true,
      "ip": {
        "address": "10.10.10.7",
        "family": "string",
        "netmask": "24"
      "ipspace": {
        "name": "Default",
      "location": {
        "failover": "string",
        "home_node": {
          "name": "node1",
        "home_port": {
          "name": "e1b",
          "node": {
            "name": "node1"
        "node": {
          "name": "node1",
        "port": {
          "name": "e1b",
          "node": {
            "name": "node1"
      "metric": {
        "duration": "PT15S",
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
        "timestamp": "2017-01-25 11:20:13 +0000"
      "name": "dataLif1",
      "probe_port": 64001,
      "rdma_protocols": [
        "roce"
      "scope": "string",
      "service_policy": {
        "name": "default-intercluster",
      "services": [
        "data_nfs"
      "state": "string",
      "statistics": {
        "status": "ok",
        "throughput_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
      "subnet": {
        "name": "subnet1",
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
53282769
Not all nodes support enabling the LIF recommendations feature.
53282770
No matching subnets are configured in IPspace.
53282772
Not enough available IPs in subnet.
53282773
Not enough locations available on node for subnet.
53282774
The specified SVM UUID is invalid.
53282775
The specified SVM name is invalid.
53282776
The specified SVM name and UUID do not match.
53282777
The specified SVM does not exist in the IPspace.
53282778
53282779
The specified IPspace UUID is invalid.
53282780
The specified IPspace name is invalid.
53282781
The specified IPspace UUID and name do not match.
53282782
The specified service policy UUID does not exist.
53282783
THe specified service policy UUID and name do not match.
53282784
The specified service policy does not exist in the SVM.
53282785
The specified service policy does not exist in the IPspace.
53282786
The specified broadcast domain does not exist.
53282787
The specified broadcast domain UUID and name do not match.
53282788
The specified broadcast domain UUID does not exist in the IPspace.
53282789
The specified broadcast domain name does not exist in the IPspace.
53282790
The specified subnet UUID does not exist.
53282791
The specified subnet UUID and name do not match.
53282792
The specified subnet does not exist in the IPspace.
53282793
The specified subnet does not match the specified broadcast domain.
53282794
The specified subnet name does not exist in the IPspace.
53282795
The specified subnet name does not exist in the broadcast domain.
53282796
The specified SVM has a type that is not supported.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
ip_interface_recommend_message
recommend
messages
array[ip_interface_recommend_message]
Messages describing the results of a LIF recommendation request.
self
ip_info
IP information
address
string
IPv4 or IPv6 address
family
string
IPv4 or IPv6
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
ipspace
Either the UUID or name must be supplied on POST for cluster-scoped objects.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
broadcast_domain
Broadcast domain UUID along with a readable name.
_links
_links
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
home_node
_links
_links
name
string
uuid
string
node
name
string
Name of node on which the port is located.
home_port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links
_links
name
string
node
node
uuid
string
node
_links
_links
name
string
uuid
string
port
_links
_links
name
string
node
node
uuid
string
location
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node. For PATCH, set is_home to true to revert a LIF back to its home port.
auto_revert
boolean
failover
string
Policy that defines where an interface is permitted to move on failover. The policy named “default” implements the recommended best practice for NAS LIFs on the current platform and cluster, and was known as “system_defined” in the CLI.
home_node
home_node
home_port
home_port
is_home
boolean
node
node
port
port
throughput
The rate of throughput bytes per second observed at the interface.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
metric
The most recent sample of I/O metrics for the interface.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
service_policy
_links
_links
name
string
uuid
string
throughput_raw
Throughput bytes observed at the interface. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
The real time I/O statistics for the interface.
status
string
throughput_raw
throughput_raw
timestamp
string
ip_subnet_reference
A named subnet. Either UUID or name can be supplied on input.
_links
_links
name
string
The name of the subnet. If only the name is provided, the IPspace scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the subnet.
svm
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST.
_links
_links
name
string
uuid
string
ip_interface
_links
_links
ddns_enabled
boolean
Indicates whether or not dynamic DNS updates are enabled. Defaults to true if the interface supports "data_nfs" or "data_cifs" services, otherwise false.
dns_zone
string
Fully qualified DNS zone name
enabled
boolean
The administrative state of the interface.
ip
ip_info
IP information
ipspace
ipspace
location
location
metric
metric
name
string
Interface name
probe_port
integer
Probe port for Cloud load balancer
rdma_protocols
array[string]
Supported RDMA offload protocols
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
service_policy
service_policy
services
array[string]
The services associated with the interface.
state
string
The operational state of the interface.
statistics
statistics
subnet
ip_subnet_reference
svm
svm
uuid
string
The UUID that uniquely identifies the interface.
vip
boolean
True for a VIP interface, whose location is announced via BGP.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
